MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
porlockweir
Oct 24, 2019Guide
Installed this update yesterday, and then spent the next 6 hours attempting to have a workable network, factory resetting twice in the process. Issues are:
- Random blocking of devices when access control is switched on – including at times Orbi satellites. This includes devices being blocked while attempting to carry out actions on the web interface (e.g. it let me log in but then blocked the device I was using when I went to the factory reset page) and reblocking devices 5 min after being added to allowed list.
- Internet connection constantly dropping out until factory reset for a second time
- Web interface not functioning properly, e.g. the button to confirm factory reset would not work
- The renaming issue that others have experienced
This is the worst update I have experienced to date (and this is my third fourth Netgear router), and totally unacceptable. I know some recommend a factory reset every time you update, but why should we have to spend time reinputting settings every time?
TeslaRMP
Dec 17, 2019Aspirant
Same problem! Not only do my device names not change, or if i can get them to change they revert back on their own later, but my Access Control keeps randomly blocking allowed devices even though they are listed in the Allowed Devices list. Netgear, please fix this! I literally did a factory reset several times and redid all my settings and port forwarding from scratch in an attempt to reset everything, but the problem keeps happening!!!!
- FURRYe38Dec 17, 2019Guru - Experienced User
Did you update your system to v2.5.1.8 yet? This seems to fix the device naming issue. I checked mine and it is working now.
TeslaRMP wrote:Same problem! Not only do my device names not change, or if i can get them to change they revert back on their own later, but my Access Control keeps randomly blocking allowed devices even though they are listed in the Allowed Devices list. Netgear, please fix this! I literally did a factory reset several times and redid all my settings and port forwarding from scratch in an attempt to reset everything, but the problem keeps happening!!!!
- Tinkman65Dec 17, 2019Aspirant
Yes I did the update but I still am unable to update device names. I had to roll back to v2.3.5.34 and now I can name devices.
What browser are you using? Did you factory reset after applying v1.8 and then clear ALL browser caches then setup from scratch on the RBR? I usee Opera for mine. I manually updated and I didn't factory reset. I was able to name 4 devices and they all have stuck and remain as configured with custom names.
Working for others as well:
Tinkman65 wrote:Yes I did the update but I still am unable to update device names. I had to roll back to v2.3.5.34 and now I can name devices.
- TeslaRMPDec 17, 2019Aspirant
I didn't know about the new version because when I do the "check for update" it said "no new firmware version available." So then I manually downloaded and updated to the new firmware version 2.5.1.8. After updating, it took a couple tries renaming before it took, but it looks like this fixed the problem. Before this update they would't change at all. Time will tell if the names change again. Thanks for letting me know about the new firmware version!
FURRYe38 wrote:Did you update your system to v2.5.1.8 yet? This seems to fix the device naming issue. I checked mine and it is working now.
Yes v38 and v40 had the device naming issue. v1.8 may not be posted to the update servers however they posted it for manuall download and manuall installation.
Glad the new FW works for you.Enjoy.
TeslaRMP wrote:I didn't know about the new version because when I do the "check for update" it said "no new firmware version available." So then I manually downloaded and updated to the new firmware version 2.5.1.8. After updating, it took a couple tries renaming before it took, but it looks like this fixed the problem. Before this update they would't change at all. Time will tell if the names change again. Thanks for letting me know about the new firmware version!
