MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Tinkman65
Dec 17, 2019Aspirant
Yes I did the update but I still am unable to update device names. I had to roll back to v2.3.5.34 and now I can name devices.
Dec 17, 2019Guru
What browser are you using? Did you factory reset after applying v1.8 and then clear ALL browser caches then setup from scratch on the RBR? I usee Opera for mine. I manually updated and I didn't factory reset. I was able to name 4 devices and they all have stuck and remain as configured with custom names.
Working for others as well:
Tinkman65 wrote:Yes I did the update but I still am unable to update device names. I had to roll back to v2.3.5.34 and now I can name devices.
- Tinkman65Dec 17, 2019Aspirant
No, I just upgraded to v2.5.1.8 and was using the edge browser and was unable to even update 1 device. I did not reset my router because then that would be one more thing I would have to setup all over again. It's bad enough I spent all the time setting up my devices the first time but to have to do a reset and setup everything again is just brain damage.
- FURRYe38Dec 17, 2019Guru
Next time try Opera or Firefox browsers. Be sure to clear ALL browser caches before entering in to the RBRs web page.
It's working.
