chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
pablohoney
Nov 13, 2019Luminary
It must be a slow roll out as when I check for updates both my router and satelitte are showing as up to date on .38
Nov 13, 2019Guru - Experienced User
You can manually download and manually upgrade v40 if you want too. I loaded mine last nite, factory reset. Loaded backup config file.
http://kb.netgear.com/en_US/000061393/
pablohoney wrote:It must be a slow roll out as when I check for updates both my router and satelitte are showing as up to date on .38
