chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
pablohoney
Nov 13, 2019Luminary
It must be a slow roll out as when I check for updates both my router and satelitte are showing as up to date on .38
CrimpOn
Nov 13, 2019Guru - Experienced User
pablohoney wrote:It must be a slow roll out as when I check for updates both my router and satelitte are showing as up to date on .38
My system on 2.3.5.30 also shows "No new firmware." In other words, Netgear is no longer encouraging updates past 2.3.5.30.
