chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
tomschmidt
Nov 12, 2019Virtuoso
I manually updated my firmware from V2.5.0.38 to V2.5.0.40 to see if it would also fix the device naming issue. It did for some devices, but others it will not allow me to change. So the v40 hot fix did not resolve the device naming issue. Note that I did not do a factory reset as it takes me hours to reconfigure the device manually. I did not test v40 for the https issue that it is supposed to address.
EduardH
Nov 14, 2019Guide
Hi all,
I spoke with NETGEAR support.
Netgear refers to the .30 as “the last stable version” this version does not have the device naming issues. I will not upgrade to .40 seems a very small fix and existing problems still occur.
- Wire1852Nov 14, 2019Apprentice
AND WHY DOESN'T NETGEAR POST AN ANNOUNCEMENT ON THESE FORUMS THAT 2.3.5.30 IS "THE LAST STABLE VERSION"?
AND WHY DOESN'T NETGEAR POST AN ANNOUNCEMENT ON THE NETGEAR DOWNLOAD SITE THAT 2.3.5.30 IS "THE LAST STABLE VERSION"?
Whoever is the Program Manager for the Orbi Firmware Development should be fired immediately. After 2 failed firmware releases credibility is gone.
EduardH wrote:
Hi all,
Netgear refers to the .30 as “the last stable version” this version does not have the device naming issues. I will not upgrade to .40 seems a very small fix and existing problems still occur.- Retired_MemberNov 14, 2019
Here's my thought on the current NG firmware testing/ implementation:
When a firmware is believed to be ready for first time release, it is made available by way of the Orbi login - user manually updates.
This firmware may have 'bugs' which hopefully will be reported, NG responds, fixes, and re-issues (same number?) the firmware, this time as a auto push for it is felt all bugs have been worked out.
Under this process, those that choose to manually upgrade their firmware in essence have become a part of the beta tester group.
I say this for I don't perform manual updates, yet over time (6 months) my firmware is updated with firmware that back 6 months ago was full of problems, yet my network continues to hum along with No changes on my part.
Just my 2 cents. Your mileage may vary.
Since you don't do manual updates you really aren't aware of the current process. If you login to the router through the web and go to firmware updates you see an online update page & a manual update page. The online web page indicates if there is a new update and you can update if desired. The manual web page requires you to first download the firmware you want installed & then you install it.
If Netgear tells you new software is ready to be installed & you install it & encounter problems, the user is not responsible for this blunder, Netgear is.
You seem to be sold on auto updates yet people have reported that their system was auto update to V 2.5.0.38 and then they had to rollbacked to a more stable version. Netgear has not indicated what the requirements are for an update to done on a specific system or user. By your logic since you depended on the auto update to be ok and it was bad, then you're partially to blame for Netgear mistakes.:smileysad: Bottomline - it's totally Netgear's screwup.
Netgear's Orbi won a lot of awards/recommendations this year. I wonder what the response will be in 6 months when those organizations update people on the product's stability & Netgear's support to it?
Retired_Member wrote:Under this process, those that choose to manually upgrade their firmware in essence have become a part of the beta tester group.
- OHChristineNov 14, 2019Tutor
Alos, as someone who just purchased an Orbi in the past month, and who immediately just went ahead and downloaded the most recent firmware update (.038) , why wouldn't Netgear make their MOST STABLE version available for download?
I'm not a supertech genius, but I'm experiencing connectivity issues (on just two Apple devices) and trying to troubleshoot. I'd like, before going through the hassle of boxing it up and returning it, the option to use THE MOST STABLE FIRMWARE. Why wouldn't a company allow that?
Now they get my return.
OHChristine wrote:Alos, as someone who just purchased an Orbi in the past month, and who immediately just went ahead and downloaded the most recent firmware update (.038) , why wouldn't Netgear make their MOST STABLE version available for download?
I have to ask.....define 'downloaded'
How was this performed? After the initial install?
