chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
Burr
Nov 17, 2019Aspirant
Beta testers... Hmmmm...when I worked in Web Testing and there was little to no Regression or QA testing (because no one wants to ever pay for thorough testing) we called this the **T.I.P** method...
*Test In Production*
What a mess!
jinnyleaf
Nov 17, 2019Guide
I also had loads of issues with .38 (particularly, slow/dropping WiFi on iPad devices). I have since downgraded to .30 and all those problems have gone away.
Not getting NG anymore after this router. :smileyindifferent:
- FURRYe38Nov 17, 2019Guru - Experienced User
Try this to see if this helps with wifi issues. I haven't seen any thing like with on my RBK50...
jinnyleaf wrote:I also had loads of issues with .38 (particularly, slow/dropping WiFi on iPad devices). I have since downgraded to .30 and all those problems have gone away.
