chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
tomschmidt
Nov 12, 2019Virtuoso
I manually updated my firmware from V2.5.0.38 to V2.5.0.40 to see if it would also fix the device naming issue. It did for some devices, but others it will not allow me to change. So the v40 hot fix did not resolve the device naming issue. Note that I did not do a factory reset as it takes me hours to reconfigure the device manually. I did not test v40 for the https issue that it is supposed to address.
atanvarno
Nov 19, 2019Guide
With the 2.5.0.38 my satelites were obviously connected as the attached devices had internet connection, but in the router web UI they were not appearing, at all. It just said, number of satelites: 0.
So I first manually updated RBR50 to .40 after which the satelites were listed, but with 0 devices shown on them. This at least allowed me to update both satelites manually to .40 just to keep things on the same version.
But I still don't see any devices shown as attached even though they are, since I have internet connection on them. It's a mix of AV receivers, Macbook Pros, iPhones, iPads, Apple TV etc.
Even more ludicrious is the attached screenshot, showing the satelites as disconnected while I'm typing this connected to one of them.
- BurrNov 19, 2019Aspirant
atanvarno , I had something very similar. All satellites and devices appeared when using -.38 firmware, updated firmware to Hotfix -.40 and no satellites/devices appear. I downgraded firmware to -.30 and everything appears again. I was having so many connectivity issues with my Ring Doorbells and version -.38 that I thought I'd go back to older firmware and test that out for a bit.
- EduardHNov 19, 2019GuideGuys, I wrote this earlier. I have spoken with Netgear support and they told me that they see .30 as the last stable firmware version. I downgraded and indeed, issues are gone. I also asked them when a safe, stable release will be announced but he could not reply to this. The .30 version does not have the naming issues etc.
- FURRYe38Nov 19, 2019Guru - Experienced User
- atanvarnoNov 19, 2019Guide
That's an amazing statement. .38 appeared as regular stable update, with notification. How can something like that be pushed and be considered non-stable is beyond my understanding.
- AnonymousNov 19, 2019
atanvarno wrote:That's an amazing statement. .38 appeared as regular stable update, with notification. How can something like that be pushed and be considered non-stable is beyond my understanding.
The real question is how many folks downloaded it on their own when their network was working fine.
