chrisuk
Nov 10, 2019Aspirant
Orbi Firmware Update 2.5.0.40
Does anyone know what's in 2.5.0.40? All I can see from the software release is "Updates the https certificate" - it's described as a Hot Fix, but I would love to see a tad more detail. I had...
Nov 26, 2019Guru - Experienced User
Are you seeing problems with v38 loaded? Some users didn't see problems. Some did. Some also factory reset and setup from scratch.
If your not seeing any problems you can stay where your at and wait for the next update to come out, or install v34.
You can upgrade or downgrade by manually downloading the FW files from NG download web page and manually install the RBS FW first then the RBR. I recommend factory reset and setup from scratch to give the FW a good installation and configuration. Use a wired PC and IE11, Firefox or Opera browsers any time to do this process.
Zephyr3200 wrote:I installed the firmware 2.5.0.38 on my RBK50. No more available on the website.
i see that the last stable current version is now 2.3.5.34.
What do i do now?
Do I have to go back to avoid further problems ?
And if so, how we do that?
Thanks for your help.
Retired_Member
Nov 26, 2019
FURRYe38 wrote:Are you seeing problems with v38 loaded? Some users didn't see problems. Some did. Some also factory reset and setup from scratch.
What you meant to say was most had problems with v38 and a factory reset is for lost passwords. If your not seeing any problems, then leave your network alone.
