GoneForRide
Jun 29, 2022Initiate
Orbi Firmware update issues RBS40 w/two RBS20 satellites
So, I have the lastest version for the router and one of the satellites, but it fails to update the "office" RBS20. It won't even allow manual update as it only sees the RBR40. Even the latest Or...
- Jun 29, 2022
Glad you got it updated!
You can always manually update it in the future if you'd like. Just make sure to update the satellites first, then the router.
You might mark it solved so others aren't trying to fix it and so they can see what did fix it for you.
GoneForRide
Update: So. It looks like IT DID UPDATE. I manually powered off the satellite (minute off). Then powered on, Then did another firmware check from my iphone app (there was an update to the app ! Well well).
And now the satellite (both RBS20) show correct, latest version.
So, nevermind. But I will say, don't use Firefox. Instead, I use Chrome (on Mac) as FF hangs there at Firmware check... but not with Chrome. I don't use Safari so that might be an option.
- plemansJun 29, 2022Guru - Experienced User
