BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jul 17, 2018Guru - Experienced User
That links to a different user. Please make a new post and share the details of your problem.
ds-will wrote:
I posted a link to more details. Here it is again: https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-stopped-my-LAN/td-p/1594578
SDplinker
Jul 17, 2018Guide
Thanks for the replies! My "unmanaged switch" is my old router with the wifi turned off. Semi-managed switch?? LOL. Maybe there is still enough going on to cause problem. Regardless I plan to get an unmanaged 8 port becuase i'm maxed anyway. Just wanted to try out what I had. Appreciate the links to order of operations - will have a go.
Thanks
Casey
- FURRYe38Jul 17, 2018Guru - Experienced User
Let us know how it goes when you get the non managed switch in.
Good Luck.
Thanks
Casey
