BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
tsig
Sep 20, 2018Luminary
balderdash. You may be having problems, but the vast majority of these systems are working just fine.
steve8411
Sep 20, 2018Apprentice
Or maybe those folks just dont realize that the Orbi is the culprit...
For the longest time, I was blaming Apple because my Apple products seemed to be the only devices having issues ...
Turns out, it's the flawed Orbi software ... then after paying greater attention, I discovered other devices were losing the connection while showing connected ...
- BBQNOOBSep 20, 2018Guide
Is there a way to roll back and block auto updates?
NETGEAR: what is your plan to fix this problem?
