mojoprime
Dec 23, 2017Aspirant
Orbi firmware update v2.1 fail
ok, i'm trying to manually update the firmware. so i got through the login page, get to the advance menu, click on manual, select my satellite and tap the update button. this is what i get -- on Safa...
DarrenM
Dec 27, 2017Sr. NETGEAR Moderator
Have you tried to power cycle the satellite before trying to do the update?
DarrenM
- mojoprimeDec 28, 2017Aspirant
thanks for the reply. since the update was pulled, should i just wait?
- mojoprimeJan 03, 2018Aspirant
Darren, should i wait until the firmware update is officially reposted?
- DarrenMJan 03, 2018Sr. NETGEAR Moderator
You can wait if you do not need the new features of circle parental controls and ethernet back haul but when trying to manually load the firmware did you unzip the file you downloaded before trying to load it onto the orbi unit?
- mojoprimeJan 04, 2018Aspirant
yes, i tried to upload the unzipped file.
