stevedfive
Nov 15, 2019Aspirant
Orbi firmware update
I currently have V2.3.5.30. Do I need to update my firmware?
Nov 15, 2019Guru - Experienced User
You can if you want to. You may see notifcation on the RBRs web page about v38 or v40. You don't have to update to these versions. IF your system is working, and your not effected by any of the release notes seen in v38 or v40, keep whats loaded.
v38 introduced one problem of device custom names. Some are bothered by this. NG is aware of it.
Be sure you make backup configurations of your RBR to file for safe keeping.
