JMU1998
Dec 19, 2017Luminary
Orbi firmware v2.1.1.16 discussion
do we need to do nvram wipe for this 2.1.1.16 Firmware just released today? noticed it downloaded automatically.
Retired_Member
Dec 20, 2017Is there a proper way to perform a firmware update? Some manufacturers recommend a complete reset to factory default then do the update. What does Netgear recommend?
Glenee
Dec 20, 2017Apprentice
I don't know if this is the proper way, but it is the way I do it with Orbi. I only do manual updates. This means you have to download the frimware update image from Orbi website first. Check to make sure you have both the one for the router and the satellite and they are the correct one you want. I update the Satellite first. I then update the Router. I then check to make sure all firmware is showing correctly on each unit VIA my Orbi information page. I then unplug Modem, Router, and satellite. I also unhook cable input from modem. I then hook cable back to modem and plug it in. I then plug in the router and then the satellite. The wait for lights to go out.
Check to see if all is good on test.
