OrbiMan
Dec 20, 2017Luminary
Orbi firmware v2.1.1.16 incorrect report device attachment
I have updated 2.1.1.16. I noticed that the device attachment page seems to be ok initially but I noticed my device was likely to more stuck on 2.4 ghz so I turned on fast switching after that everyth...
allroadusa
Dec 20, 2017Guide
Same here. After a while, router UI reports allmost all devices connected to router but this is not actually the case : devices continue to be connected to the nearest satellite.
Furthermore, satellites display no connected device.
This lack of visibility is not a pleasant thing but actual system behavior is still normal.
- CotedanDec 30, 2017Apprentice
Same thing here. Everything works fine and stable. Using wired to satellite. All devices connected to satellite are showing as "wired" though and I can't determine what speed they're connected to (2.4 or 5).
Also, Genie app sometimes shows all my 45 devices, but often, it will just show one (e.g. iPad) as if it was the only thing connected.
