OrbiMan
Dec 20, 2017Luminary
Orbi firmware v2.1.1.16 incorrect report device attachment
I have updated 2.1.1.16. I noticed that the device attachment page seems to be ok initially but I noticed my device was likely to more stuck on 2.4 ghz so I turned on fast switching after that everyth...
RonaldJanssen
Dec 22, 2017Star
Exactly the same situation here. Also satellites are connected by ethernet and devices that are wireless connected to a satellite get reported to be connected by wire to router......
Everything works though....
DarrenM
Dec 27, 2017Sr. NETGEAR Moderator
We are aware of these issues and are working on fixing the UI to display the correct info.
DarrenM
- JMU1998Dec 27, 2017Luminary
I mentioned already in another thread but was really hoping that they would update the "Device Type" listing to label attached devices the choices available for selecting labels for device type is very limited and not updated for many Firmware versions. Netgear Engineering if you are reading this and while fixing devices showing all connected to main please update device type listing/selectable option as well...example no option for Echo dot, Reciever, notebook, switch, modem, camera, Ring Doorbell, VoIP phone, AmazonFireTV etc...list very outdated!
- RonaldJanssenDec 27, 2017Star
Indeed, visual aid when maintaining the list works really good, if the images are up to date!
