Mrpopup
Mar 27, 2019Tutor
Orbi Firmware V2.3.0.32
Netgear site still shows that Orbi Firmware V2.3.0.32 is NOT to be installed in Australia (so I assume also NOT in New Zealand).
Is this still correct, or can NZ'ers and Aust'ers install this updat...
- Apr 01, 2019
Thanks for letting us know. Please mark your post thread as solved.
Enjoy.
Mar 27, 2019Guru - Experienced User
Note:
If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212. After updating the firmware v2.2.1.212, your Orbi router will reboot, and then you can update to v2.3.0.32.
If you are located in the following regions Japan (JP), Australia (AU) and Canada (CA) please hold off updating to FW 2.3.0.32
Though NZ is not mentioned. since your in the same region as AU, I presume this includes NZ.
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
