Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Oct 31, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? Please give this a try. I manually loaded v38 on my RBK50 and saw no wifi issues after loading v38.
NG doesn't annouce when new FW will be forth coming.
JKNIE wrote:Hi
Since updating my Orbi system to V2.5.0.38 I am experiencing:
- WiFi outages (randomly the WiFi is gone)
- On the configuration page in a browser it says that the two satellites are not connected but the App says they are?
- The device attached list if randomly empty or contains only a few of the attached devices
I assume this is due to a buggy upgrade - question is when will new version come and when it down how will I update when the satellites are showing as not connected?
Christian_R can you tell me when a new version will be out?
Regards
John
Retired_Member
Oct 31, 2019
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update? Please give this a try. I manually loaded v38 on my RBK50 and saw no wifi issues after loading v38.
According to NG...."A factory reset is necessary when you cannot recover your password."
JKNIE wrote:Hi
Regards
John
