Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
JKNIE
Oct 31, 2019Tutor
Hi
Since updating my Orbi system to V2.5.0.38 I am experiencing:
- WiFi outages (randomly the WiFi is gone)
- On the configuration page in a browser it says that the two satellites are not connected but the App says they are?
- The device attached list if randomly empty or contains only a few of the attached devices
I assume this is due to a buggy upgrade - question is when will new version come and when it down how will I update when the satellites are showing as not connected?
Christian_R can you tell me when a new version will be out?
Regards
John
ryanaroha
Nov 02, 2019Star
JKNIE wrote:Since updating my Orbi system to V2.5.0.38 I am experiencing:
I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.
- Retired_MemberNov 02, 2019
why did you upgrade?
- ryanarohaNov 03, 2019Star
Retired_Member wrote:
ryanaroha wrote:
I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.why did you upgrade?
I can't tell if you're trolling, trying to be self-righteous, or just clueless. I think you and I are on the same team here, dude.
To say what I shouldn't have to say: I expect a firmware upgrade will fix CVEs (enhancing security), patch minor flaws (fixing stability bugs), and occasionally add big new features that I probably don't care about. A company as big as Netgear should QA their damn firmware. A new firmware shouldn't cripple user experience.
- Retired_MemberNov 04, 2019
I agree with what you say. In my opinion your only mistake was to manually upgrade when I believe your system was working fine...??
- FURRYe38Nov 03, 2019Guru - Experienced User
Factory reset the RBR and RBS and setp from scratch. This should fix your problems.
ryanaroha wrote:I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.
FURRYe38 wrote:Factory reset the RBR and RBS and setp from scratch. This should fix your problems.
I'm fine with the inconvenience of a factory reset IF I can restore settings from backup, but "setup from scratch"??? WTF. That's insane. Some people actually configure more than just SSID and passphrase on their wifi routers.
I'm downgrading to 2.3.5.30.
