Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
ryanaroha
Nov 02, 2019Star
JKNIE wrote:Since updating my Orbi system to V2.5.0.38 I am experiencing:
- WiFi outages (randomly the WiFi is gone)
I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.
Nov 03, 2019Guru - Experienced User
Factory reset the RBR and RBS and setp from scratch. This should fix your problems.
ryanaroha wrote:I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.
- ryanarohaNov 03, 2019Star
FURRYe38 wrote:Factory reset the RBR and RBS and setp from scratch. This should fix your problems.
I'm fine with the inconvenience of a factory reset IF I can restore settings from backup, but "setup from scratch"??? WTF. That's insane. Some people actually configure more than just SSID and passphrase on their wifi routers.
I'm downgrading to 2.3.5.30.
