Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Nov 03, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
abonko wrote:Ever since upgrading to this version of the firmware, the quality of our internet has been terrible. 1) Videos being streamed will hang for a few seconds; 2) Internet connectivity will periodically drop completely, requiring me to reboot the Orbi. When this happens, the app will say the Internet is offline; 3) My device list in the app has become completely corrupted. It lists more/fewer devices than are actually connected and device names are all messed up (my laptop in the list now has the name from another device).
I genuinely hope this is being looked into as a matter of urgency, because the poor quailty of this build is appaling.
And yes, I did a factory reset afterwards and that has made no difference.
Anonymous
Nov 03, 2019Admit the firmware is bad and stop asking folks to jump through hoops
