Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Retired_Member
Nov 02, 2019
ryanaroha wrote:
JKNIE wrote:Since updating my Orbi system to V2.5.0.38 I am experiencing:
- WiFi outages (randomly the WiFi is gone)
I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.
why did you upgrade?
ryanaroha
Nov 03, 2019Star
Retired_Member wrote:
ryanaroha wrote:
I've been seeing the same over the last few days, ever since doing the update. Maddening. Wifi is constantly dropping on all devices, even when sitting right next to the satellite.why did you upgrade?
I can't tell if you're trolling, trying to be self-righteous, or just clueless. I think you and I are on the same team here, dude.
To say what I shouldn't have to say: I expect a firmware upgrade will fix CVEs (enhancing security), patch minor flaws (fixing stability bugs), and occasionally add big new features that I probably don't care about. A company as big as Netgear should QA their damn firmware. A new firmware shouldn't cripple user experience.
- Retired_MemberNov 04, 2019
I agree with what you say. In my opinion your only mistake was to manually upgrade when I believe your system was working fine...??
