Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Nov 03, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
abonko wrote:Ever since upgrading to this version of the firmware, the quality of our internet has been terrible. 1) Videos being streamed will hang for a few seconds; 2) Internet connectivity will periodically drop completely, requiring me to reboot the Orbi. When this happens, the app will say the Internet is offline; 3) My device list in the app has become completely corrupted. It lists more/fewer devices than are actually connected and device names are all messed up (my laptop in the list now has the name from another device).
I genuinely hope this is being looked into as a matter of urgency, because the poor quailty of this build is appaling.
And yes, I did a factory reset afterwards and that has made no difference.
ryanaroha
Nov 03, 2019Star
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Dude are you out of your mind or can you really not accept the possibility that this firmware is buggy?
All of these things you ask about and mention DO NOT MATTER if the system was working great prior to the change of a single variable -- the firmware upgrade. What you're doing here is akin to gaslighting.
For the record, I have had a similar experience to abonko ... I've had an Orbi + a satellite for 2.5 years and they've worked pretty much flawlessly, through every upgrade, until this week with v2.5.0.38. Given that no other variables changed, it makes zero sense for you (FURRYe38) to be wasting your + our time asking about modem, home square footage, channel settings, etc. I'm sure you have the best of intentions, and I appreciate that you're willing to spend your time trying to be helpful, but please stop for a minute and think about the logic of this situation, and what you're suggesting.
- FURRYe38Nov 03, 2019Guru - Experienced User
