Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
JKNIE
Oct 31, 2019Tutor
Hi
Since updating my Orbi system to V2.5.0.38 I am experiencing:
- WiFi outages (randomly the WiFi is gone)
- On the configuration page in a browser it says that the two satellites are not connected but the App says they are?
- The device attached list if randomly empty or contains only a few of the attached devices
I assume this is due to a buggy upgrade - question is when will new version come and when it down how will I update when the satellites are showing as not connected?
Christian_R can you tell me when a new version will be out?
Regards
John
JKNIE
Nov 03, 2019Tutor
I did a factory reset and got up and running.
Interestingly I didn't have to manually update the firmware to 2.5.0.38 as this seems to happen automatically after I did the factory reset (which might explain why the first boot after reset took a long time).
The system is working but I'm not sure it's stable as its not reporting all attached devices even when some of the un-reported devices have Internet connection so they are connected.
Let's hope the next version is better.
Thanks for the help.
John
- FURRYe38Nov 04, 2019Guru - Experienced User
Let the system settle in and give it some time to see if the devices appear. NG is ware of the device naming problem found.
JKNIE wrote:I did a factory reset and got up and running.
John
