Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
JKNIE
Nov 03, 2019Tutor
I did a factory reset and got up and running.
Interestingly I didn't have to manually update the firmware to 2.5.0.38 as this seems to happen automatically after I did the factory reset (which might explain why the first boot after reset took a long time).
The system is working but I'm not sure it's stable as its not reporting all attached devices even when some of the un-reported devices have Internet connection so they are connected.
Let's hope the next version is better.
Thanks for the help.
John
Nov 04, 2019Guru - Experienced User
Let the system settle in and give it some time to see if the devices appear. NG is ware of the device naming problem found.
JKNIE wrote:I did a factory reset and got up and running.
John
