Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
abonko
Nov 05, 2019Star
FURRYe38 - I appreciate that your intentions are pure and you are genuinely trying to help, but as ryanaroha pointed out, if everything was working perfectly beforehand then why are these questions even necessary? Maybe it's a mistake on my part for not pointing out such detail in the first place. So allow me to set the record straight.
My satellite Orbi is connected to the primary Orbi via a physical LAN cable, utilizing Ethernet Backhaul. My primary router is connected to my Comcast router which is setup in bridge mode. This is the exact configuration I have run for nearly a year now without a single issue. In fact, the performance and stability of this configuration has been so amazing I have raved about the Orbis to friends, family and anyone else who would listen.
You could argue I chose to apply the firmware update, but given how much I was pestered to upgrade via the Orbi app I'm not sure that's an entirely fair assessment. Nonetheless, I upgraded. Within an hour of upgrading all of my issues began. I can say with absolute certainty that not a single other aspect of my network configuration changed. Hence, the only logical cause of my issues is the firmware upgrade. All other possible variables are irrelevant.
Someone earlier mentioned downgrading back to the previous version. How do you do that? Is it only through the desktop login?
Thank you everyone for the feedback.
Nov 06, 2019Guru - Experienced User
Yes these questions are necessary. Each user has different configurations and experiences which we don't know about fully unless we ask some specific questions.
Like, "Has a factory reset and setup from scratch been performed since last update?" I and others are not seeing these issues you post about with v.38 as we apply FW updates manually and reset and setup from scratch.
I have asked others as well to factory reset there system and setup from scratch and this has resolved there problems. A factory reset and setup from scratch is a last resort and valid step to see if problems will be resolved.
You can downgrade as well and thats your choice. However you may run into this issue again upon next FW update the NG comes out with.
Good Luck.
- AnonymousNov 06, 2019
Factory reset should be viewed as a last resort. Understand problems with firmware releases before hand.
- TpaveyNov 09, 2019StarI have the same issues. My Orbi was the best router I've had, now its among the least reliable. I lose connection so much I often disable wifi on my cell. I've done the factory reset. It made no difference. There is something wrong with the firmware.
- FURRYe38Nov 10, 2019Guru - Experienced User
Revert back to what was working for you then.
- abonkoNov 10, 2019Star
Here's an update on my latest, in the hopes it helps narrow down the cause of the issues.
I finally broke down and performed a Factory Reset and completely setup my network again from scratch. Although this did help marginally, stability is still not back to what it was before this Firmware. My devices still lose Wifi connectivity, albeit not as frequently as before. The interesting observation is that the connectivity issues give the appearance of the Wifi range being reduced compared to the previous Firmware version. I highly doubt this is case, and as such I have simply dismissed this as being just more of the same overall connectivity issues I have been experiencing since upgrading. I will see how this plays out over the next week and may decide to rollback to the previous Frimware version next weekend.
- TpaveyNov 10, 2019StarMy issues had to do with internet connectivity, not connecting to the router. I would frequently get an exclamation point in my Android status bar. My roku would need to be put through wireless setup to reconnect. Basically, it seemed that once a device was connected and actively using the internet, all was well. If a device went "idle" it would stay connected to the router but be cut off from the internet.
I hope those are helpful observations. - abonkoNov 11, 2019Star
I can now confidently confirm that the Factory Reset did not resolve my issues. Today I was standing right next to my satellite and my phone informed me I had no internet connectivity through wifi and asked if I wanted to switch to celluar data. Looks like I'll be rolling back to the previous firmware version this weekend.
- FURRYe38Nov 12, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Lets us know how it turns out after reverting back FW.
abonko wrote:I can now confidently confirm that the Factory Reset did not resolve my issues. Today I was standing right next to my satellite and my phone informed me I had no internet connectivity through wifi and asked if I wanted to switch to celluar data. Looks like I'll be rolling back to the previous firmware version this weekend.
