Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Nov 10, 2019Guru - Experienced User
Revert back to what was working for you then.
Tpavey wrote:
I have the same issues. My Orbi was the best router I've had, now its among the least reliable. I lose connection so much I often disable wifi on my cell. I've done the factory reset. It made no difference. There is something wrong with the firmware.
Tpavey
Nov 10, 2019Star
I did revert back. Hopefully all is well again.
I really hope that Netgear figures out what is causing problems for some people so future updates don't have this issue. I'd hate to not be able to have a critical update (security) because it breaks my internet.
- AnonymousNov 10, 2019
Tpavey wrote:I did revert back. Hopefully all is well again.
I doubt the version that broke your system had critical updates. Those are pushed automatically
