Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Nov 12, 2019Guru - Experienced User
What Mfr and model ISP modem are you using with the Orbi?
skimmilk0000 wrote:This is happening to mine as well. Web traffic in general seems the most problematic, and switching between ISP, Google and 1.1.1.1 DNS servers did not help.
I did a factory reset of both the satellite and router. I've turned off daisy chaining, fast roaming and nothing is helping. I have HomeKit so downgrading to .30 isn't really an option and I was on a much older firmware (2.3.x) before so I'm not sure how far back I can go.
Retired_Member
Nov 13, 2019
FURRYe38 wrote:What Mfr and model ISP modem are you using with the Orbi?
Stop asking about modems when everyone knows the problem is with v2.5.0.38
- FURRYe38Nov 13, 2019Guru - Experienced User
Modems is part of it. I'll post how i see fit. Your not the director here.
Have a nice day.
- Retired_MemberNov 13, 2019
FURRYe38 wrote:Your not the director here.
Never said I was. You're wasting peoples time while you know the firmware is faulty.
Works for me and others. Your posts and attitude towards me says otherwise. Last time. I post how I see fit and it's up to users to take it or leave it.
Good Day.
FURRYe38 wrote:Works for me and others. Last time. I post how I see fit and it's up to users to take it or leave it.
Good Day.
You never have provided who these 'others' are. Dozens come in here asking questions and seeking help concerning a corrupt firmware (which is widely know to have issues) and all you want to do is check everything from the shoe size to the kitchen sink.
but keep it up, for the alert users will pick up on your travesty and 'leave it'
Good Day.
- TpaveyNov 13, 2019StarIf you can't see that saying, "works for most" is incredibly flawed logic, I dont know what to say.
I will say that this rabid defense with comments like "you're not the director here" and general lack of inaction on Netgear's part makes me weary of future Netgear purchases.
This is a community forum for users of products to give valuable feedback for FREE. These are generally early adopters provided an expanded soak test. It's also clear that many of the people posting here with problems have as much networking knowledge as you portray. You should treat them like they should be valued.
Not once have I seen, they are aware of issues and are working on it... which frankly is unacceptable. - TpaveyNov 13, 2019StarOh, by the way, I have a fully updated Netgear CM600 modem. If you are going to tell me that the Orbi cannot work nicely with another Netgear device I'm definitely not buying any more products from them.
I do treat users with problems as valued users and my intent is to help them. It's some who take my "FEEDBACK" out of context and seem to believe that i'm some how hidering help when I'm actually trying to help them and figure out what the real problems are. Some seem to be annoyed that I don't follow there way of giving help and information or methods of getting routers working. I don't have to nor will I for these people. Been doing this for for a while now and if you could see the feedback I get from solved problems you think other wise. Thats fine if you think I'm not trying to help anyone or causing problems. I'm only here to help out and yes, I give my persective and observations of what works for me as well. If I didn't I wouldn't be giving forthright information and experiences to others. Again it's up to users to take accept the information provided or not. All users here in the forums are just that, users. We don't work for NG either. I only report to NG forum moderators and nobody else. Only the forum moderators see be on the books.
"Can lead people to water. Can't make them drink."
Good Day.
Having a modem only is recommended instead of a modem combo unit. Unless you have bad cabling or bad ISP signals to the modem or a bad configuration of the Orbi, I wouldn't see why they wouldn't work otherwise.
Tpavey wrote:
Oh, by the way, I have a fully updated Netgear CM600 modem. If you are going to tell me that the Orbi cannot work nicely with another Netgear device I'm definitely not buying any more products from them. - Retired_MemberNov 13, 2019
FURRYe38 wrote:I do treat users with problems as valued users and my intent is to help them. It's some who take my "FEEDBACK" out of context and seem to believe that i'm some how hidering help when I'm actually trying to help them and figure out what the real problems are.
That's just it, (in the case of these firmware issues) you're not pointing them to the real problem when you know yourself what it is. Why do you insist on numerous troubleshooting questions, knowing that its related to the firmware? Even if the answer was unknown, basic troubleshooting 101 takes the process in steps. One at a time.
"Can lead or horse to water. Can't make it drink." -People are NOT horses.
Good Day.
- TpaveyNov 13, 2019StarI'm not sure why you quoted me when talking about modem router combos. The CM600 is a Netgear Cable Modem. It has zero router capability.
I'm still waiting to hear the solution. Under the old firmware, this was the best router I've had. Under the new firmware it didn't work. It didn't work 2 feet from the main unit. It didn't work 2 feet from the main unit with the satellite disconnected. It didn't work 2 feet from the main unit after a factory reset with just the basic settings. It didnt work after a factory reset with my old settings. It repeatedly disconnected my devices. I reset my modem. I reset my router. I cleared and reconfigured the internet settings on my devices. None of this worked. Again, this was from the main router. Distance to satellite, wall composition, nor anything else was in play. Heck, the orbi app couldn't find the router half the time which uses the internal network, not the internet. This bypasses the modem.
Magically everything was perfect again after a rollback to previous firmware. After the rollback I didnt need a factory reset. I didnt need to restart devices. Nothing. Its crystal clear what the problem is.
Maybe you should gather serial number data. Maybe it is a batch issue. Maybe a supplier change on a part caused a problem.
If Microsift released an update that forced users to wipe their computers, for even 1% of the people, how long would they leave that update floating around? They'd pull it and internally investigate. I've seen no indication that Netgear has even acknowledged this.
You have people here that have spent hours reconfiguring after resets. One went to the trouble to bypass a switch to humor you. After all that you have the gall to say "you can lead a horse to water...."?
I've dealt with some bad customer and community support, but this... - Retired_MemberNov 13, 2019
Tpavey wrote:
. Under the old firmware, this was the best router I've had. Under the new firmware it didn't work.Just curious.....did you ever tell us how you came upon the 'new' firmware? The OP is about v2.5.0.38.
- TpaveyNov 13, 2019StarI opened my orbi App to look at a "newly connected device" that I later realized was an old tablet of mine, (internet was working fine) and I decided to look for an update since I was there. I hit the search for update function and it installed. I didn't have to seek this out and upload it manually. This is a wide release that will likely mean a lot of new Orbi users will be returning products.
I usually operate under the assumption that updates make fixes and improvements to security, stability, and features. Because of this, I tend to update when available for all my devices, TV, Roku, Ring, phone, computer, game consoles, etc... often these updates fix newly exposed exploits.
Now, I've learned my lesson and wont be doing that with Netgear products unless there is a security issue. This likely isnt what Netgear would suggest given the router searches for updates on initial setup. They recommend keeping the product up to date - Retired_MemberNov 13, 2019
Thanks
I don't use the app. What I see (when i do login to the router using a web browser) is whether or not a firmware update is 'available'. I do NOT click on it. Mainly because my system is working.
From what I understand, firmware updates with major revisions (to include security) are pushed auto by NG, no action required app or otherwise.
