Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Tpavey
Nov 13, 2019Star
I opened my orbi App to look at a "newly connected device" that I later realized was an old tablet of mine, (internet was working fine) and I decided to look for an update since I was there. I hit the search for update function and it installed. I didn't have to seek this out and upload it manually. This is a wide release that will likely mean a lot of new Orbi users will be returning products.
I usually operate under the assumption that updates make fixes and improvements to security, stability, and features. Because of this, I tend to update when available for all my devices, TV, Roku, Ring, phone, computer, game consoles, etc... often these updates fix newly exposed exploits.
Now, I've learned my lesson and wont be doing that with Netgear products unless there is a security issue. This likely isnt what Netgear would suggest given the router searches for updates on initial setup. They recommend keeping the product up to date
Anonymous
Nov 13, 2019Thanks
I don't use the app. What I see (when i do login to the router using a web browser) is whether or not a firmware update is 'available'. I do NOT click on it. Mainly because my system is working.
From what I understand, firmware updates with major revisions (to include security) are pushed auto by NG, no action required app or otherwise.
