Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
Nov 13, 2019Guru - Experienced User
A reset maybe needed next time you do an update. Something I don't experience with v38.
Glad downgrading worked to resolve this.
Enjoy.
skimmilk0000 wrote:
FURRYe38 wrote:What Mfr and model ISP modem are you using with the Orbi?
skimmilk0000 wrote:This is happening to mine as well. Web traffic in general seems the most problematic, and switching between ISP, Google and 1.1.1.1 DNS servers did not help.
I did a factory reset of both the satellite and router. I've turned off daisy chaining, fast roaming and nothing is helping. I have HomeKit so downgrading to .30 isn't really an option and I was on a much older firmware (2.3.x) before so I'm not sure how far back I can go.
I have an Arris DG1670 in bridge mode.
My wired AppleTV is working just fine so it seems to be the wifi.
Downgrading appears to have resolved these issue at the least so its tied to the latest firmware.
skimmilk0000
Nov 13, 2019Aspirant
FURRYe38 wrote:A reset maybe needed next time you do an update. Something I don't experience with v38.
Enjoy.
There were resets everywhere that did notthing. Also another symptom was some devices losing wifi connection altogether, particularly older i devices.
- FURRYe38Nov 13, 2019Guru - Experienced User
Ok, thanks for letting us know. Hopefully next FW push will won't be problematic for you.
Enjoy.
