Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
jinnyleaf
Nov 16, 2019Guide
Have you tried the .40 firmware?
I was also having lots of issues with .38 (slowdown especially on iPads), but the .40 hot-fix seems to have resolved many of the issues.
I'm tempted to go back to .30, because I remeber that everything was really good prior to .38
Thanks!
SW_
Nov 17, 2019Prodigy
jinnyleaf wrote:...
There isn't any documented change between v38/40 that would have magically resolved network/slowdown issues. It's likely a result of Orbi network starting to settle down since upgrading to v38, then again from v38 to v40. Unless clients continue to have WiFi connectivity issues, I would stick with v40 a bit longer and see if things improve/stabilize over time. Good luck either way!
