Christian_R
Oct 23, 2019NETGEAR Employee Retired
Orbi Firmware v2.5.0.38
Hello Orbi Community,
As you may be aware, there has been a new firmware version available for the RBR50 & RBS50. To access the firmware version, please use the links below:
RBR50: v2.5....
jinnyleaf
Nov 16, 2019Guide
Have you tried the .40 firmware?
I was also having lots of issues with .38 (slowdown especially on iPads), but the .40 hot-fix seems to have resolved many of the issues.
I'm tempted to go back to .30, because I remeber that everything was really good prior to .38
Thanks!
abonko
Nov 17, 2019Star
Thanks!
I looked into it, but the release notes state that the only fix is an SSL certificate issue. There's no way that would have adressed all the issues I was having, so I didn't both trying it out.
- jinnyleafNov 19, 2019Guide
abonko wrote:
jinnyleaf wrote:Have you tried the .40 firmware?
Thanks!
Thanks.
I downgraded to .30 and life is good again. :)
- migstaNov 19, 2019Apprentice
Downgrade or reset to factory defaults is the usual stupidity by which Netgear has us ensurning that their stuff works. And, 99.9% of the time resetting to factory defaults does nothing. This thread is also about devices being broken and not some certificate issue. For me, the devices issue is even present in .30 - so sorry this is not fixed whatsoever.
- FURRYe38Nov 20, 2019Guru - Experienced User
Maybe you can ask others what they did that got theres working:
or contact NG support.
migsta wrote:Downgrade or reset to factory defaults is the usual stupidity by which Netgear has us ensurning that their stuff works. And, 99.9% of the time resetting to factory defaults does nothing. This thread is also about devices being broken and not some certificate issue. For me, the devices issue is even present in .30 - so sorry this is not fixed whatsoever.
