freebo99
Apr 13, 2017Tutor
Orbi for gaming, does PC or console connect to satellite or router?
Hi if your on a console or gaming pc and they are nearer the satellite not the router and connect to the satellite does this slow your ping, lag or slow your response time? thx
- Apr 14, 2017
TheEther wrote:2ms is 0.002 seconds or 1/2000 seconds. It's not likely to be noticeable, unless perhaps you are a pro-gamer. Another way of looking at it is that 2ms is the difference between 83 fps and 100 fps.
1 ms is one one-thousandth of a second. So, actually 2 ms is 2/1000 seconds, not 1/2000 seconds. 1/2000 would be 0.0005 or a half-millisecond.
The border of human perception is about 13 ms, so you won't likely be able to tell the difference between 2 ms.
rhester72
Apr 13, 2017Virtuoso
In my experience, the satellite backhaul adds roughly 2-3ms of latency.
Rodney
- freebo99Apr 13, 2017Tutor
hi
do you get the option to specify in the orbi router setting if you want to connect to the route or the satellite because if i get orbi the satellite is more for the tv and cable tv / satellite tv box and the router itself should be within good range for the pc and gaming console?
thx
