freebo99
Apr 13, 2017Tutor
Orbi for gaming, does PC or console connect to satellite or router?
Hi if your on a console or gaming pc and they are nearer the satellite not the router and connect to the satellite does this slow your ping, lag or slow your response time? thx
- Apr 14, 2017
TheEther wrote:2ms is 0.002 seconds or 1/2000 seconds. It's not likely to be noticeable, unless perhaps you are a pro-gamer. Another way of looking at it is that 2ms is the difference between 83 fps and 100 fps.
1 ms is one one-thousandth of a second. So, actually 2 ms is 2/1000 seconds, not 1/2000 seconds. 1/2000 would be 0.0005 or a half-millisecond.
The border of human perception is about 13 ms, so you won't likely be able to tell the difference between 2 ms.
rhester72
Apr 13, 2017Virtuoso
In my experience, the satellite backhaul adds roughly 2-3ms of latency.
Rodney
freebo99
Apr 13, 2017Tutor
hi
do you get the option to specify in the orbi router setting if you want to connect to the route or the satellite because if i get orbi the satellite is more for the tv and cable tv / satellite tv box and the router itself should be within good range for the pc and gaming console?
thx
