freebo99
Apr 13, 2017Tutor
Orbi for gaming, does PC or console connect to satellite or router?
Hi if your on a console or gaming pc and they are nearer the satellite not the router and connect to the satellite does this slow your ping, lag or slow your response time? thx
- Apr 14, 2017
TheEther wrote:2ms is 0.002 seconds or 1/2000 seconds. It's not likely to be noticeable, unless perhaps you are a pro-gamer. Another way of looking at it is that 2ms is the difference between 83 fps and 100 fps.
1 ms is one one-thousandth of a second. So, actually 2 ms is 2/1000 seconds, not 1/2000 seconds. 1/2000 would be 0.0005 or a half-millisecond.
The border of human perception is about 13 ms, so you won't likely be able to tell the difference between 2 ms.
gfrey
Apr 13, 2017Apprentice
If you are worried about 2ms of latency then you should really hard wire your PC or console to the router. I have my kids XBox hard-wired and I play some Warcraft on my PC via Wifi satellite. I have never noticed any latency. I have 1Gbps AT&T fiber and I get around 150Mbps from each of my satellites via Wifi. I love the Orbi system!
freebo99
Apr 14, 2017Tutor
hi
am i right in thinking 1ms is 10th of a second? 100th if second, 1000th?
if 2ms is 2000th of a second then i guess that it isnt noticeable?
thx
- TheEtherApr 14, 2017Guru
- st_shawApr 14, 2017Master
Oops. Fat-fingered that one. Thanks for the correction.
