ipswichclam
Sep 02, 2020Aspirant
Orbi frequently loosing connection and turning magenta
My set up: Fios Actiontec MI424WR rev e, router conneted to Fios ONT via MOCA 2.0, feeding RBRB50 with three satellites (large 3 story house). I also have some TIVO minis connected via Moca 2.0/c...
Sep 02, 2020Guru - Experienced User
Is the orbi hardwired into the actiontec via ethernet or do you have a moca setup running it?
Is the orbi running in AP mode?
ipswichclam
Orbi is hardwired by ethernet to the actiontec. Orbi is in AP mode (not router) because I had my router set up with some custom port forwarding.
