Lesvee
Dec 03, 2019Follower
Orbi frequently shows NOT FOUND 104
My Orbi is connected to a Vodafone router (my service provider) and then wirelessly to an RBS50 satellite. I frequently see the message 104 NOT FOUND when looking at web sites using Orbi network H...
Dec 03, 2019Guru - Experienced User
SInce you have a router built in to the ISP modem, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
