Chickenlips
Feb 23, 2018Aspirant
Orbi Frozen
This morning I woke up and my Orbi has vanished! No sign of it on my wifi network. I have powerwashed, nothing. Tried resetting, unresponsive. Connecting via ethernet, no joy. It is completely unresp...
Feb 23, 2018Guru - Experienced User
Have you power cycled the system OFF then back ON after 1 minute?
If so, try a factory reset and set up from scratch?
Chickenlips
Hi, Yes as mentioned in the original post I have power cycled and the reset button is unresponsive. The unit is as if it has been frozen and will not respond to anything I have tried. I have seen another post whereby someone else had the same issue and was sent a replacement.
- FURRYe38Feb 23, 2018Guru - Experienced User
Please contact your regional NG support office on the phone.
- ChickenlipsFeb 24, 2018Aspirant
Thank you I will try again tomorrow although my 90 day free support is up I appear to have hardware cover for another year.
- FURRYe38Feb 24, 2018Guru - Experienced User
Get it looked at soon. Good Luck.
