LLcdPH
Nov 12, 2017Aspirant
Orbi Functionality lost when setting up as an access point?
I'd like to connect the Orbi (AC2200) router to the LAN port of an existing ASUS gigabit wireless router. I'm assuming it needs to be setup in access mode? If I do, what functionality (if any) woul...
LLcdPH
So you lose LOAN out on the router and satilites?
LLcdPH
Make that... You lose LAN out?
- st_shawNov 13, 2017Master
No. Access Point mode turns off Orbi’s routing functions, but your ASUS will be doing the routing, so no loss of LAN or WAN access.
- jdpg2Nov 13, 2017Apprentice
Think of it this way
AP Mode : The Orbi provides wireless connectivity( both main and guest) to your network but that is all. All routing features such as DHCP, QOS, DDNS, DMZ, UPnP, VPN, any routing rules etc are all provide by your ASUS router. You must remember to Disable the wireless feature on your router.
