UnixGuy
Mar 14, 2017Guide
Orbi generating a lot of ARP traffic on WAN
Using Orbi, I have problems being deactivated by my ISP due to too much ARP noise on the wan port. Reported this to support but no luck so far getting any help so wanted to see if anyone have similar...
- Aug 16, 2017
V1.12.0.18 fixed the issue!
UnixGuy
May 21, 2017Guide
Quick update:
tested a beta firmware with no improvement, maybe even worse..
upgraded to 1.9.1.12 a couple of weeks ago after a couple of hours I could see an ARP storm, over 100 packets per s. with requests from the router to my ISP default gw and my ISP blocked my port automatically (No blame on them as this is clearly the Netgear router misbehaving).
Seems I'm stuck using the orbi as an AP and use another router, or I might just return it. I wouldn't recommend it to anyone. Netgear has been working on the problem for over 2 months. Orbi is not a new product anymore and I doubt they will spend much time on new firmware versions going forward.
fefigno
Jun 16, 2017Guide
UnixGuy, same thing here. Do you have any news?
- fefignoJun 17, 2017Guide
For the record, I had my ISP increase DAI limit to 50 ARP requests per second and I didn't see a disconnection in the last few days. Before I had 5-10 each day.
- fefignoJun 18, 2017Guide
Some more info:
- All of this still happens with latest firmware as of 18 June 2017. Router Firmware Version V1.10.1.2.
- I have definitely much less disconnects now, though I still had one yesterday. So yes, it seems Orbi can actually send more than 50 ARP/s.
- I also opened a case with Netgear, explained the issue and provided links to this forum thread.
- So, it's clear there's a problem and it's clear they know well. If this doesn't get fixed, it's either Netgear unwilling or unable to fix it
