UnixGuy
Mar 14, 2017Guide
Orbi generating a lot of ARP traffic on WAN
Using Orbi, I have problems being deactivated by my ISP due to too much ARP noise on the wan port. Reported this to support but no luck so far getting any help so wanted to see if anyone have similar...
- Aug 16, 2017
V1.12.0.18 fixed the issue!
UnixGuy
Jul 01, 2017Guide
Just upgraded my orbi to a beta 1.12.0.12 that is supposed to solve the problem. Has been running fine for a day now so looks promising.. but sometimes if has been days before the problem occurred before as well.
I haven't been able to convince my ISP to do any changes on their side and they have the limit set to 50 packets per sec.
SamuelHringdu
Aug 08, 2017Aspirant
Curious to know whether the beta firmware solved it or if the issue still there?
- fefignoAug 16, 2017Guide
- Stumpper98Jan 03, 2018Aspirant
Running V2.1.1.16 (as of 1/3/2018)
My Orbi log is full of "DoS Attack: ACK Scan" (ARP traffic)
Intermittent wireless/dropped WiFi connection
Sometimes having to reset the connection by unplugging the modem
I will call my IPS to have my connection raised to 100 ARP/s
I called my IPS to have my connection limit raised to 100 DAI reqs/sec
The phone rep. could not find any info on "DAI" limit
I have an appointment with a field reps later today.
- UnixGuyJan 11, 2018Guide
no, the beta didn't solbe the problem, but as posted below - the later official versions did.
