UnixGuy
Mar 14, 2017Guide
Orbi generating a lot of ARP traffic on WAN
Using Orbi, I have problems being deactivated by my ISP due to too much ARP noise on the wan port.
Reported this to support but no luck so far getting any help so wanted to see if anyone have similar experiences?
My ISP uses Cisco DAI where the orbi (after a couple of days use) breaches the set limit of 50 arp packets per s.
After persuading the ISP to manually re-enable my port a couple of times, I hooked up the orbi to my pc, acting as a router in front of internet.
Using wireshark to analyse the traffic, I can see the orbi continuously sending multiple arp requests per second to the (simulated) default router on the wan side. The router answers back nicely so no reason for orbi to ask again milliseconds later.
I will monitor for a couple of days and suspect to see the same breach identified by my ISP. Already seen up to 10 ARP requests per s, which (including ARP responses) would breach the Cisco default of 15 pps.
- Problem still there after upgrade to 1.5.0.12. Will try the newer 1.8.0.6 as a next step. Tried to find what has actually been fixed but seems Netgear is not open with this and support will not tell..
- Arp traffic on wan link still there without any clients on the LAN
- Disabled UPnP but no difference (and this shouldn't generate traffic on the wan anyway, right?)
- Orbi log warned about a DoS ARP attack at the time it breached the 50 limit so seems it detects there's a problem - just isn't aware it created it itself;)
Any ideas?
Any ideas?
V1.12.0.18 fixed the issue!
