Roamabout
Feb 27, 2018Luminary
Orbi Guest network question
I enabled the guest wifi today in anticipation of having some people over tomorrow. I changed the ssid but left it with no security. My intention was to enable it while people are here then turn it o...
Roamabout
Feb 28, 2018Luminary
I did some tests early this morning before everyone was awake. Enabling and disabling the guest wifi is a slow and disruptive event, not something I want to do when a freind stops by. I opted to leave it enabled but added a password.
Feb 28, 2018Guru - Experienced User
Ok, Ya, I'll give this a try with mine as well. See what happens. AFter hours LOL.
I would contact DarrenM and give him a link to this and give him all your info. I'll post back here with anything I find.
- t_kFeb 28, 2018Luminary
FURRYe38 ... You replied to his question with a conjecture that you didn't test - even though you had the hardware handy to conduct a test - and told him to ask somebody else. That has to be most pointless thing.
Roamabout You already know the answer to this question, but I want to add a touch of context. This isn't a netgear-specific behavior. In general, whenever you change the exposed SSIDs or their settings on a radio, the radio needs to be restarted. Since the Orbi's replicate their configuration from the router this chaining reboot is required.
Said differently, Orbi restarts are required for any SSID changes - guest or otherwise. Unfortunately, the Orbi's take a while to reboot :-(.
- RoamaboutFeb 28, 2018Luminary
t_kwrote:FURRYe38 ... You replied to his question with a conjecture that you didn't test - even though you had the hardware handy to conduct a test - and told him to ask somebody else. That has to be most pointless thing.
Understood, thanks. I was not expecting it to be quite that disruptive and the combination of the slow start and synch in addition to the somewhat unpredictable behavior after a restart led me to realise that this was not a feature that you just turn on and off when you need it without consequences.
I'm fine with enabling it and leaving it on with some security that is not too hard for my visitors to configure.
