Lkgibso
Dec 05, 2016Follower
Orbi guest network setup
I'm unable to set up a guest network follow the steps on net gears help pages as there isn't a guest network icon under the home section of orbi setup screen. Has someone successfully set up another n...
peteytesting
Dec 05, 2016Hero
first you need to make sure you have updated the orbi to fw version 1.4.0.16
the guest network section will then be there
