whsbuss-1
Jan 20, 2017Apprentice
Orbi guest network setup
I have a question before I buy the Orbi. Can you enable the guest network when bridge/AP mode is selected?
- Jan 20, 2017
I have an Orbi in AP mode and the option to enable the Guest Network is present.
st_shaw
Jan 20, 2017Master
- rhester72Jan 21, 2017Virtuoso
st_shaw wrote:I have an Orbi in AP mode and the option to enable the Guest Network is present.
...but useless, currently. There's no LAN isolation whatsoever in AP mode.
Rodney
- st_shawJan 21, 2017Master
rhester72 wrote:...but useless, currently. There's no LAN isolation whatsoever in AP mode.
Rodney
Good point. Not completely useless though. You can still avoid giving out your normal WiFi password to guests, and maybe you aren't concerned about them snooping on your network. I think one of the mods said isolation would be available in a future firmware release.
