pafjf's avatar
pafjf
Follower
Jan 28, 2017
Orbi guest network setup
Hi   I am thinking of buying the Negear Orbi (the two pack).  I have an existing Tiligin modem/router that is getting long in the tooth so I am thinking of buying a stand alone modem to use alongsi...
  • DarrenM's avatar
    Jan 30, 2017
    Hello pafjf
    The CM400 will work for your 100 MBPS connection but if you look to get faster speeds in the future you may want to look at the CM500 CM600 or CM700.
    DarrenM
