mjbauer
Aug 27, 2017Aspirant
Orbi Guest Network
After setting up a guest network (broadcast SSID, no password) Internet and netowrk access would stop. Orbi utility on my phone (iPhone) could not fiind the Orbi netwrok A reboot of the system solved...
mjbauer
Aug 28, 2017Aspirant
Thanks for the tip!
Do you recommend trying the systems firmware update or manual? How do I find the latest version of the firmware for the units?
Thanks again
Mike
Arjun0o
Aug 28, 2017Guide
Latest firmware for RBR50 is 1.12.0.18. Try to upgrade to the latest firmware version by using the GUI of the router, if that does not work, you will have to do it manually. Ping me, I will let you know the steps.
