kenquick
Mar 06, 2017Guide
Orbi Hard Reset Crashes - Require Reboot
Dear Community, Is it just me or does anyone elses Orbi crash and either reboot or require a hard reset. I have a medium sized network with 25 devices that are a mix of everything. IOS, IoT, Smarth...
DarrenM
Mar 10, 2017Sr. NETGEAR Moderator
Hello Kenquick'
I would try removing devices one at a time to see which device could be causing the issue first one I would try is the powerline adapter.
DarrenM
- kenquickMar 15, 2017Guide
Darren,
I am trying your advice. I will report back. Though I dont have a solution to remove the Powerline Adapter. I will try to make it a Static IP, since I am seeing alot of DHCP logging from that device.
Has anyone else also seen a lot of DHCP request from Apple devices. Seems like those devices also cause some problems. I am trying to see if that causes some concerns.
There must be a little better way than remove one device at a time and just wait. Let me know if you have any other tips.
Thanks,
