alpacafarm
Nov 14, 2019Follower
Orbi hardwired satellite dropping connection and switching subnets
I have the Orbi RBR50 with 2 sattelites. One of the sattelites is a bit far from the main Orbi with a spotty connection, so I have it hardwired to the Orbi. The main Orbi is on 192.168.1.1 . The S...
lando786
Nov 14, 2019Aspirant
I can't get my satellite to get a decent connection anymore either. It was working fine but started getting random "config sync" status while wireless so I switched to wired. The connection on wired is somehow worse. It just comes on in the UI and randomly disappears. This things a expensive piece of poop.
Dec 02, 2019Guru - Experienced User
Is your SSID name separated on the RBR by chance?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last update?
