alpacafarm
Nov 14, 2019Follower
Orbi hardwired satellite dropping connection and switching subnets
I have the Orbi RBR50 with 2 sattelites. One of the sattelites is a bit far from the main Orbi with a spotty connection, so I have it hardwired to the Orbi. The main Orbi is on 192.168.1.1 . The S...
Dec 02, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Please try a factory reset and setup from scratch with the RBR and RBS.
alpacafarm wrote:I have the Orbi RBR50 with 2 sattelites. One of the sattelites is a bit far from the main Orbi with a spotty connection, so I have it hardwired to the Orbi. The main Orbi is on 192.168.1.1 . The Sattelite periodically (very often) drops its connection and starts giving out 192.168.9.1 subnet IPs to wifi devices connected to it, preventing internet connections. Is there a way to prevent the sattelite from doing this, and why does it switch subnets and lose connectivity when it is hardwired to the main Orbi? It's been doing this ever since I got this thing over a year ago. I have it updated to the latest firmware (V2.5.0.38).
thanks
